Bd transmission pressure enhancer
Bryce_fow
Has anyone used this I have a weird 2 to 3 shift not all the time just every so often just seeing if anyone has put one in
Are you wanting this for a bone stock truck? As in no weight loss?
Looks like it would be an option for the guys that have tuning but haven't gotten trans tuning yet.
I would think that it might cause harsh shifts??
Bryce_fow
She is on weight watchers i know I am just kinda wondering if there was a problem with them having a line pressure problem
gotchadollar
I have a built trans stock solenoids and i see over 220psi all the time wot is right around 255psi. i don't think this will solve any issues, if it has harsh shifts or delays chances are you have to much clearance in the clutches.
Bryce_fow
I got it in today so hoping to get it in the trans by Friday Ford is out of lv should be getting some in two days so fingers crossed
Bryce_fow
How are you watching line pressure I used FORScan and I am a little confused haha I was trying to do a before and after
gotchadollar
Through ezlynk. The most accurate way would be a manual gauge though
Bryce_fow
I hooked a friend of mines up and it only shows desired
Bryce_fow
today is the day sorry no update I have been busy doing r&d
Bryce_fow
So FYI the ats pan holds 18qts and the only reason I got it is because it helps it’s strength should have got a smaller one but as far as the bd pressure it was extremely easy to install I have not drove it yet because I had to get my son ready for school but I will let you know tomorrow what I think
