Bench Flash?
Faster
The cab was off my 08 6.4 and since then it won't take a tune, just bricks the ecu every time i try. SCT has reset my tuner a few times and even replaced it once.
Basically I just want to bench flash a tune from my live wire onto the PCM and TCM so i can at least drive my truck while I search for the culprit.
Any help finding someone that can get this done would be greatly appreciated.
Thanks
I have a used pcm with a H&S deelet tune on it I could send you...not sure what job your truck is-if was out of a 2010
Faster
If it was the right pcm, would that be a plug and play thing, or would i need to have it updated with anything to make the truck work?
Also, what level tune is on it now?
Would be plug and play . There will be a ton of soft codes due to vin mismatch ect but it should run the truck at least. Only issue I can think is if the Pats goes crazy
