Flash_Outdoors
I feel like the truck is excessively “blowing off” when shifting into OD. Just normal driving it’s a “shooschhh”. If I’m getting on it then it’s a WAY stronger “shooschhh” or even a “chchchch hooschhh”
Couple things I’ve noticed:
1. After the truck is started after it has been sitting for an hour or so, at idle about 5-10 seconds after starting I hear a “thump” or a “clunk” from under hood.
2. I installed the riff raff OCR to get rid of the overboost code I was getting. The code still pops up and I know it’s installed correctly.
I’m thinking about replacing the wastegate control valve or the actuator. Am I on the right path or should I look somewhere else?
