Boost gauge issue
Twoodz
Midland,pa
Ok, 11 250 w 116k ...boost gauge is going crazy ...under 10 psi works great , over 10 , it will rise and drop and rise and drop . Holding pedal steady , not shifting ....worse w a load on it . Just replaced the vacuum boost thing by the thermostats housing . ... made a big difference in running , but gauge is still floating around , but not as bad . What to go to next ??
webb06
Seneca, MO
Map sensor. Or if you have a way to monitor map voltage and see if it’s going wild
Twoodz
Midland,pa
Checked map sensor , cleaned it and was watching it on the scanner while driving ....when boost drops it drops . Thinking that there may be a boost leak ??? I also just got a p1249 code .
webb06
Seneca, MO
Check the hot side cac pipe for crack
