Bore scope through injector cup?
MeTo
Has anyone tried to bore scope through an injector cup hole to check for a cross hatch on a cylinder wall with the piston at the bottom of the stroke? I know that hole is small.
gotchadollar
I’ve got the snap on bore scope that will do it, I had to buy the smaller camera attachment for it to work. It has a bottom and side camera to look at the piston and sidewalls.
MeTo
I thought the glow plug was smaller in diameter. I will check that.
Have you actually viewed cylinder walls? If so, is the resolution such that a cross hatch be determined?
gotchadollar
Ive looked through the injector hole. And yes you can see the cross hatches in the cylinder wall.
MeTo
Great, I have work to do.
My engine has about 114,000 on it and over the last year, blow by is increasing. I checked the compression and the driver's side is ~360 with the passenger side ~340. My oil pan is weeping a little also.
So, I'm going to pull it as soon as the weather is reasonable here in NE Wisconsin. Hopefully it will be a matter of a rering and a reseal?
Is it possible to pull the engine without removing the radiator support and stuff forward of it? I.e. just the radiator, fan, clutch and all that crap.
gnxtc2
Bergen County, NJ USA
Yep. I left the radiator in when I had to pull my motor to seal the oil pan. Just removed the fan/fan clutch from the water pump.
Billy T.
gnxtc2@aol.com
