Brake problems
94.5 Stroker
Lincoln, Nebraska
So I'm looking at another truck and will have to haul it out of there if I get it. Well long story short, my pedal was feeling kinda soft. So I had a tech at work drive my truck to see what he thought, he said the master cylinder was bad. So I put one in today and vacuum bled it twice and now I have no brakes:fustrate:. Another tech that was helping me tonight says it is the booster because the pedal drops to the floor and it drops if you pump it up and start it. I guess that is what I am gonna do tomorrow unless their is anything else you guys think to check. Wheel cylinders have been checked and they are fine.
Thanks Cody
Parker, TX
Did you bleed it at the RABS valve (it has a bleeder). When my booster went bad, I still had brakes, but the pedal would sort of "suck down" almost faster than I was pushing it and it would not return as fast as it should when letting off. Cheers!
