Power Strokes
94-97 Aftermarket
Can precise shift points be tuned via chip?
[QUOTE="Wackerjr, post: 105977, member: 130"] If it is going in a 5spd then the controller is the best option. The pcs that many of us use is the best thing out there for the 4r100 IMO.. and yes when I tell it to do something it does it....sometimes to well.... :) remember your going to have to buy the harness from ford to work with the new trans and pcm anyways... when you add that into the mix... the pcs aint that much more and the harness is already prewired ready to go for the pcs from them..... Give Jacob at WOP a call he can set you up with everything you need....one other thing it will gain you the ability to have a data logger for all the above... [/QUOTE]
Truck slipping into 4th
Latest: Sterling6.7
Friday at 7:18 PM
6.7 Tech
Latest: DEEZUZ
Apr 23, 2025
Newly Enlisted
Latest: ghohouston
Apr 23, 2025
7.3 Aftermarket
O
2011-2016 Radiator upgrade
Latest: OtisCreekConstruction
Apr 23, 2025
6.7 Tech
Performance shops
Latest: DEEZUZ
Apr 22, 2025
7.3 Performance
Power Strokes
94-97 Aftermarket
