Carli
dstryr
Gilroy CA
So after some scrambling with some ****ty family / gf issues I decided to screw it and go big...you only live once right?
Went to pick up my Carli 2.5 " Pintop with full leaf upgrade and I was drooling the whole way home. I'm going to do the install tomorrow and I'll provide a full review and pictures but for now here are some teasers...
dstryr
Gilroy CA
This is the truck it is going on. Current setup is 5.4 coils with no rear block and overload removed with OUO bolt on traction bars. More pics tomorrow. Time to bust out the Jager bottle. Forgot to mention I think i got the last set of general grabber M/t in the country :).
BFT
southern cali
Should be an awesome set up. I got to drive sages set up on his 2011 with just the add a leaf and I was amazed!
I am going to be doing the coil over set up with added goodies
EvilTwins
Connecticut
After doing the 10" springs in mine I am a huge fan of lift springs as opposed to lift blocks. The springs are a bastard to get in but the ride and look is worth it.
Erikclaw
Central CA
Springs are a lot better in terms of stopping axle movement too. Not the solution but much stiffer than a block alone.
dstryr
Gilroy CA
As far as taking longer than it should....I'm a CNC machinist not an auto mechanic and my toolbox is loaded differently haha. I really wish I had a lift right about now.
Jerry rigging to the fullest...
O2ShootTheJ
How hard is it to install a lift? Or take one off and reinstall it? I need to get mine repowdered
Ad8 PRODIGY
Orange County, NY
If you have access to a lift, and a set of tools, pneumatic or mechanical, its not hard. Just time consuming. Probably and afternoon to part of the evening if you get hung up. Its not alot harder w/o a lift. It is more awkward though, not being at chest height.
If you dont have the original instruction manual, take a bunch of pics whenver you do something. Better to do it as preventative measures before your stuck scratching your head.
SAK
Victoria, Texas
I hope you haven't already drilled the pins in yet on the traction bars, that is the very last step you do when putting them on. Fixing the bar in place already with the truck set like that will but tension on the bar and will put the axle in a bind along with naking the pinion go up.
If you have already drilled them, you can take the pin out and then rotate the inner bar 90* and redrill the hole. This is to be done after everything is put together and the truck is sitting under its own weight.
DSTRBD
Houston
Congrats on the Carli kit, you will love the Pin-Top Kings! I run that same setup on our 2012 Dodge.
