Cat Oil Filter
vtine523
Read on some forums that the Cat 0716/1808 oil filter would fit the 7.3..... this is not accurate. The thread is the same and the length wouldn’t be an issue on a lifted truck but with oil pan modification it is about 3/8-1/2 too wide.
Just FYI
Cat
0716
1808
244-4484
All too wide without pan denting. Down to 8micron but too wide. Stick with Donaldson DBL or Wix/Napa 51734XE 10micron
Have a good one gents :blitzed:
Arisley
Arlington, Texas
Once you modify, parts that would fit on a stock motor, may no longer fit on a modified motor. But will work just fine with the original oil pan.
JCart
What oil pan modification? I use Donaldson DBL 7405 for cat engine, it’s large. Pending how you engine sits relative to cross member you may have to clearance the cross member with a flapper disc, so it doesn’t touch the x member. For reference it protrudes just below the pan on an OBS truck.
j
BS Hauler
Northeast Iowa
I tried to put the Cat filter on my stock 02 oil pan and it is about a half inch to wide. I would of had to dent the pan in to make it work.
vtine523
Exactly. Don’t over think it don’t be confused. Just trying to help
vtine523
Just FYI
Cat
0716
1808
244-4484
Typo. **Without oil pan modification. Correct may work with different pan
