centering axle on 08 f350
blk350on20s
Hey. I have an 08 with a add a leaf, 5.5" block and 1" block for around 7" of lift. The way the 08 spring sits it makes the angle of the blocks go back. My axle sits about 1.5" closer to the back. How can i fix that? Any products you have? Thanks. Ryan
Spatel23
Olive Branch, MS
are you running two blocks stacked? no bueno
get one block with a 15? degree angle on it.
on edit, I used to have a 7inch block and if I remember correctly, it only had 5* so that should do it.
Dzchey21
wyoming
It has more to do than just the angle on the block. The springs aren't drilled in the center like the older trucks
Viking
Minnesota
Ah I see how it was worded now. So I take it these blocks aren't for these leafs? I would think if the were you wouldn't have this problem.
blk350on20s
The stacked block was used to clear my paddles for the weekend. I wasnt concerned as i have traction bars as well as constantly monitored the u bolts. Like dustin said. The leaf springs slope down from back to front. So any block that goes in has an angle that goes to the back. The more block, the more the axle is placed back in the wheel well. I am running a 1" TEI spacer and 6" spring up front. I want to match that in the rear and center the axle. Its almost like i need a new spring but was trying to avoid that
