Clunking noice coming from Transfer Case?
DeclanO
Hi all, long time lurker first time poster.
2008 6.4L with 191k
Have what seems to be a clunk coming from my t-case that I notice in 2 situations.
Situation 1: At stop shifting from reverse to drive
Situation 2: Driving at speeds of 40+ when gas pedal is released then clunk happens when reengaging the gas pedal. Also experiencing some vibration.
Originally thought I was having a ujoint failing but after having truck on a lift there was minimal play.
After doing some research another possibility I have found was that the slip joint could be the culprit for this noise.
Any information or advice would be much appreciated.
-Declan
Sent from my SM-G960U using Tapatalk
Smokin 6.0
Indiana
Take the driveshaft out and see if you can wiggle the output from the transfer case and see if it wiggles ag all I have had bearings in the t case go out and cause this same situation
DeclanO
Thanks for the info, I'll do some more digging soon.
