coolant temp issue!
DillonXweston
Riverdale Utah
i put a 1999 motor in my 2002 and the coolant temp is way messed up. If i start it in the morning it reads right in the middle, then after about five minutes or so it goes up to overheated and stays. i thought it was the 99's wiring harness because it was throwing a battery light so i changed the harness it fixed the bat light but not the coolant light then we changed the gauge cluster and the water pump sensor and its still reading overheated all day any ideas??
Arisley
Arlington, Texas
If it is starting in the middle, I would think it was an electrical issue not a real temp issue. You should double check it with an old school mechanical gauge though.
ToMang07
Mainah!
:whs:
I'd check the wiring to the sensor, too....and depending on the readings get a new OEM sensor.
Diezel Dawg
Cheney, WA
Could also check.it with a heat sensing gun
Sent from my PG86100 using Tapatalk 2
DillonXweston
Riverdale Utah
its not hot tho when it says im overheated in the morning the motors still cold it doesnt make sense to me ive changed that sensor twice and also the whole wiring harness.
Arisley
Arlington, Texas
Didn't the PCM wiring change in 2002. If so, you need the 2002 wiring harness on there. May also be a different sending unit. Put one from a 2002 on there. Is the wiring connector the same as another wiring connector, could you have the connectors plugged in wrong?
DillonXweston
Riverdale Utah
i got the 2002 harness on there and ive tried a few auto zone sensors form o4riley auto and auto zone and still no dang luck. its getting frustrating not knowing how hot it is.
