Cp4
pdumont01
CT
What is that the high pressure pump? I may be able to get you the ford procedure
pdumont01
CT
Should be a link to the shop manual procedure. It works on a computer
Dzchey21
wyoming
I agree.
Its a pretty easy deal, making sure the timing is right on the pump is the worse part. And setting up the puller on the first one you do. After that its cake
Athens, IL
I agree.
Just Mark the gear so it doesn't jump teeth, loosen the nut, unbolt the pump and smack the nut with a hammer and it pops loose in 10 seconds. Cake.
