cps 10mm bracket bolt
Turbosuzuki
Louisiana
OK guys changed out my cps finally but the 10mm bolt felt loose when taking out. Sure enough it had metal all in it like it was stripped. I put the new one in but now the bolt won't tighten.
Guess it will have to go in shop the truck starts fine but if I hit a bump this new cps might move and stall the truck. I'm pissed always something I swear. Does anyone know if this can be fixed? It's not the bolt but the hole in the engine that's messed up.
can you drill it and heli coil it? its not like the bolt needs to hold much torque
Turbosuzuki
Louisiana
No sir physically I can't but I'm hoping a mechanic can do something to fix it. It's a tuff location to get into for a big guy like myself but hopefully something can be done. The bracket I can wiggle so it's not in tight at all. I don't want to drive and have the sensor come loose and the truck stall on me.
fastersteve
Mine did that also. I was able to Helicoil it by taking the fan clutch and water pump pulley off. You will need a right angle drill.
Luckily I have one of those.
Turbosuzuki
Louisiana
I don't have one of those. Looks like it's going in the shop. Thanks to everyone that replied I will let you guys know what this cost when I get it fixed.
Turbosuzuki
Louisiana
OK spoke to the mechanic. He said at the very least to put in a helicoil he would have to pull the radiator and condenser to get tools in there to work. If he can't do that he said he would have to pull the engine. Then he would have to reseal everything. Does this sound right? I will sell the Damm truck before all that crap
Zeb
Downtown Marrowbone Ky
That is ridiculous.
Turbosuzuki
Louisiana
find an actual mechanic
He worked on my last 7.3 and I had no complaints. Just seems a little much to fix a bolt hole.
I can see pulling the fan and shroud maybe even the intercooler but not the condenser also. Now I'm no mechanic so I figure I would ask you guys. I will try another place and see.
Bugman
Gypsum, Co
The problem with fixing it is that you need the correct tools to get into it to drill it out and repair the threads. Very few mechanics have a right angle drill in their tool box.
You could possibly go up one size of bolt and retap the hole for the new threads but that could be a problem also.
Turbosuzuki
Louisiana
Why may that be a problem ? What all has to be done to replace the cover? The mechanic said pulling the engine has to happen to replace it because of the oil pan
Bugman
Gypsum, Co
If the front cover needs to be removed you need to pull the engine to reseal it properly.
You may be able to do it with the engine in the truck but you are risking it leaking.
JCart
Yes definitely a pain in the arse..... Did one on my OBS once and the time is in actual pulling all the gear outta the way to access the 10 mm location. I pulled bumper and everything to front of engine off. The drilling and Helicoil takes no time really it’s just the access. SD you might have more room, but with mine as I had retrofitted a IC on.... well it is a pain for sure. Better than pulling the engine though.
The tolerance for proper fit is pretty fine (CPS), I opted not to mess with it and pulled all the front off, not that bad really or hard, just time consuming.
j
fastersteve
Sigh...you can get a right angle drill for $35 for a cheapie, $95 for an Ingersoll air drill from Amazon.
If you have ANY mechanical ability, buy a drill and put a helicoil in it.
Pulling the radiator out would probably give enough room for a regular drill. The cover is aluminum and not difficult to drill.
Turbosuzuki
Louisiana
Thanks you guys have been a big help. I pulled and changed the radiator on my last 7.3 so I know I can atleast do that. I watched some youtube videos on how to install a helicoil. I planed on doing a radiator flush anyway so loosing this piss water the last owner has in it isn't a big deal. I have a new degas bottle thermastat and housing to install also so taking it apart will let me clean stuff up.
I didn't sleep last night I need my truck.
JCart
As you’ve pulled the rad before you’ll have no problem with the rest of it. As Fastersteve mentioned a right angle drill is the call. Drill, tap, helicoil.... pretty straight forward. Once done use a little quality anti seize paste on the 10mm bolt. You’ll be up and running in no time!
cheers,
j
Turbosuzuki
Louisiana
cheers,
j
Thanks I think I may be able to do this. You guys have been great. Question how much work to remove the intercooler? Guess more room wouldn't hurt the intercooler boots look horrible with black oily dirt so I could clean that up as well.
Zeb
With the radiator out it’s a piece of cake.
