Cts turbo timer
GROSSpolluter
So Cal
I just installed the turbo time add on to my cts. It has 2 options for cool down. Time or egt. So which should I do? If egt to which temp is good to shut down?
Sent from my Samsung Note 3 using Tapatalk
WYO7.3
Wyoming
I always look for under 300 degrees which might be overkill but I'd rather, in my case, wait a few mins then coke a turbo.
greasltn
Hillsborough, NC
The genera rule is 400deg. but 300deg. is being super safe. Some people do time to suit their needs because it doesn't take these trucks long to cool down.
WoodBoy
Alabama
I would do it with time. Maybe 20-30 seconds after key is switched off. It is kinda hard to describe the reasoning behind this but your air temp doesn't really reflect the turbo temp as air temp will cool quicker than the metal components.
GROSSpolluter
So Cal
I might adjust it up to 300 when it gets hot out. But right now a or temp is low 70s so doesn't take long to get egts low.
Stroked777
Casper, Wyoming
Is this really worth having, it only takes 15-20 seconds after pulling in the driveway until mine hits 300 or below, even in the summer. Most the times it's cooled enough after me rustling around to make sure I grab everything from my truck
GROSSpolluter
So Cal
It's worth it to me when my gf does a mile long burn out down the street than comes back and turns it off.
B585Ford
WV
LOLLOL Fair enough. I got my wife trained that she has to let it get down to 300 and no one else drives my truck, but if they did, I would have one too.
Stroked777
Casper, Wyoming
They are easy to teach, mine knows to wait for that egt gauge to read 300 or below. And she yells at me if I turn it off it's it's above 300 even by one degree
WoodBoy
Alabama
Mine stays in the passenger seat, sometimes even the backseat....... Anyone else's????
