Cts2 reading ipw
spongebob915
Maryland
Who has the cts2. The website said it can read ipw. Now I just called edge and was told it was their mistake it does not read ipw.
spongebob915
Maryland
Mine does not list IPW as an available PID...I was hoping for that as well.
Their website did list it as a new pid . That was one of the reasons I sold my cts. Now there are telling me it was a mistake.
11-15
Ambient Air Temp
Accel Pedal Position
Barometric Pressure
Battery Voltage
Corrected Speed
Dist. Between Regens
Dist. Since DTC Clear
Dist. Since Regen
D P F Pressure
D P F Soot Mass
DTC Count
EGT Post D P F
EGT Pre D P F
EGT Post Turbo
EGT Post SCR/Pre D P F
Engine Coolant Temp
Engine Load
Engine Oil Temp
Engine RPM
Engine Run Time
Fuel Level
Fuel Rate
Gear with Reverse
Gear with TCL
Intake Air Temp
Manifold Abs Pressure
Mileage Coach
MPG Instant
MPG Average
x PPM
Regeneration Status
Reductant (Urea) Level
Time 0-60
Time 1/4 mile
Torque
Torque Soleid Pressure
Trans Temp
Turbo Boost
Fuel Pressure
Exhaust Back Pressure
EGR Temperature
Fuel Injector Pulse Width
Fuel Injection Timing
Charge Air Temperature
BIG JUICE
Valrico FLA
11-15
Ambient Air Temp
Barometric Pressure
Battery Voltage
Corrected Speed
Dist. Since Regen
D P F Pressure
D P F Soot Mass
DTC Count
EGT Post D P F
EGT Pre D P F
EGT Post Turbo
Engine Coolant Temp
Engine Load
Engine Oil Temp
Engine RPM
Engine Run Time
Fuel Level
Fuel Rate
Gear with Reverse
Gear with TCL
Intake Air Temp
Mileage Coach
MPG Instant
MPG Average
x PPM
Regeneration Status
Time 0-60
Time 1/4 mile
Torque
Trans Temp
Turbo Boost
Fuel Pressure
EGR Temperature
Yeah this! I have nothing extra as far as pids .... No injector anything
