D80 SRW Hub
HaysKSFirefighter
Valley Center, KS
Jared,
I found a post over on the diesel garage where you guys offered a hub to convert a D80 to SRW and allow me to go from 8x200 to 8x170. Are these still available? I'm wanting to convert over to SRW and am very interested if I can get some more info. I was going to try and tackle it myself, but if you guys already did all the work that just seems so simple :thumbsup:
Breaking Habits
Mapleton, Illinois
Sorry man didnt notice this in here. The kit has been out of production for quite a while now. I dont think Josh is going to be producing it due to lack of interest at the time of design.
If I had enough interested people I may be able to accomplish something?
Jared
HaysKSFirefighter
Valley Center, KS
There's some interest out there, I've gotten a few emails from folks looking to do the same. Any idea what it would take to have a set done or if there might be a set squirreled away somewhere? I found a bed for my DRW to SRW conversion, now I just need to do something with the rear axle.
HaysKSFirefighter
Valley Center, KS
Because I've already got a bigger axle in perfect condition under the pickup already. Plus then I won't have to worry about gear changes or anything else. Just need to figure out how to run an 8x170 end, run some 05+ wheels and 35" tires and I'll be a happy guy!
powerstroked08
Pennsylvania
Just out of curiousity, is the only differance between the drw and srw is the hubs are different? As far as the dana 80 goes.
ncollins64
winchester springs, tn
You could do what I did. Took a dually Dana 80 to my local drive line shop and took him my old sterling and he put my sterling outers on my 80. He also cut the tubes to be the right width and reused and cut and resplined the 80 shafts. Cost me about 650 total.
powerstroked08
Pennsylvania
No sh!t!!!! I think I might do that as well. Thanks a lot man!:toast:
powerstroked08
Pennsylvania
Ok out of curiousity what all needs to be done/changed? I want it to fit DIRECTLY in my 08 f350. I want the brakes and all to bolt right up. I want to use 08 brakes and what not. So whats it gonna cost(ballpark guess)?
