Dana 60 swap
mill hall, pa
I'm running an f 250 with a 4 inch lift plan on putting a 60 under it. Do they sell a drop bracket for the trac bar. I plan on using the f250 lift spring. Thanks
Sent from my SCH-I535 using Tapatalk 4 Beta
brewer
Mods, Might need to be moved to aftermarket section as you choose.
Anyways, PMF (Trevor @ Precision Metal Fab) makes drop brackets. Rough Country also sells a drop bracket for the stock bracket IIRC.
FWIW Trevor makes some nice pieces; I have his full 4.5" RSK kit on my truck.
It'll still ride like a pogo stick with those springs, just something to consider.
mill hall, pa
Thanks for the input. I did find the drop brackets. So I can get the four inches of lift I need out of the rsk kit with stock springs?
brewer
Depends on what RSK you use. SKY kit requires OBS springs (F350) unless you move the front brackets forward and weld to the frame (have to also cut your bumper, makes it hard to use aftermarket bumpers as well).
With the PMF kits it's all straight bolt on, but they require Super Duty springs.
The 3.5" kit should get you right about 4". My 4.5 kit turned out to be just under 6.
The condition of the springs you use also factors in here on actual lift height, obviously.
