DT530E
dubuque, ia
i know its gonna be tight it the same physical size as a 466e and its not all that heavy only weighs about 1400 lbs. and i was kinda planning on having to make some adjustments to firewall if i try it
Cat_rebel
Rebecca Black took my seat
What's so special about throwing a 530 into a pickup? I can see for the sake of having something different & bigger then everyone else & I won't fault you for that. However there isn't really an "aftermarket" for the 530 programming wise. I know the 8.3L Cummins with the vp44 can get a firetruck tune & put down around 400hp+. SmokyRed's boss has an 8.3L in his Superduty but he's also running rock wells IIRC.
dubuque, ia
im not thinking about it for making big horsepower and torque but more so for having something different, durability, and towing ability. plus the engine is not costing me that much if i want to buy it
Denver
America
If you want the tow ability of the 530 then you should get a truck made for a 530. Before you think of big engine for heavy loads think about the brakes and chassie strength before power.
Ad8 PRODIGY
Orange County, NY
:whs: ..... But hey just seeing your username if you want to do it then go for it! Post pics!
Cat_rebel
:whs: If your wanting a better tow rig go with a lo pro freightliner/international/ext. The first time you have to make a panic stop with a loaded gooseneck doing 70mph in a med duty you'll be glad you weren't hauling the same load with a 7000lb pickup.
abbottfarms
Maine
:whs:
But if you want to so it to be different then go for it...
derrick36
Not 100% the same but you can get an idea. Here's a dt466 stuffed in an F-Superduty.
I'm guessing the frames are different between the obs f250/350s and the F-Superduty's but you can see how much firewall fab work went into it.
dubuque, ia
thats what i wanted to see and that looks like a big hole cut into that firewall
derrick36
Yeah, you'd need a pretty good size doghouse to make that fit. Looks like the back 2 cylinders are fully in the cab. Would probably be a pita to work on if anything went wrong, but it's definitely doable.
dubuque, ia
and the electronic DTs have a much wider valve cover than the mechanical ones other than that they are about the same physical size. the 530 and 466 are about the same size
