Dual disc ceramic button clutch 7.3/zf6
mikeeg02
Drifting, PA
Dual disc ceramic button clutch, just got back from Kentucky clutch. I Upgraded to a sintered iron, and bought a whole replacement to help eliminate downtime. Setup for a 7.3 with a zf6. Everything you need (pressure plate, discs, floater, flywheel) aside from the bolts to the crankshaft, they aren't provided. $1,100 shipped to the lower 48.
mikeeg02
Drifting, PA
Pictures attached. See fresh machining. :naughty: :ford:
mikeeg02
Drifting, PA
Rated at 650 HP
I believe they replaced the pressure plate too. No marks from a table grinder, and the fingers dont have wear from a throwout bearing
this is the exact same one I have in my 01..it's a good setup for sure!!
