Dual Hpop Stealth System/ SD parts
Plimptonjr
Franksville, Wisconsin
For Sale:
Dual 17* hpop Stealth Pump System. One pump was a reman when originally assembled in 2008. Includes 2 gaskets and 2 sealing o-rings. Reservoir included that was used with it. They came off of a running and driving truck, previous owner downsized from b-codes to smaller hybrids, decided on a single. I was told there are 60k on the pumps. The pumps are mocked together in picture, final cleaning and assembly is on you.
Install Guide Here: http://www.thedieselgarage.com/projects/Stealth/
I JUST bought them through a friend of a friend, Thought I stumbled onto a good deal. After speaking with Gearhead, they said I could keep my original srp1.1 (with the warranty) and it would be sufficient. I'd like to get my money back out of the system. $950
Superduty parts came off of a (Early Model)1999 F-350:
Impeller/ Turbine wheel look in good shape, minimal(what I consider normal) shaft play - $200
Stock 15* HPOP - $200
Turbo Pedestal - $60
2 inch Plenums - $30
Spider / Spyder (Includes boots to plenums)- $120
Intercooler pipes - $120
Fuel Pump Bracket/holder - offer
Fuel Bowl/lines - offer
IN-Tank filter/pickup - offer
up-pipes(passenger side tube slides out when bolted together. I can weld it or leave it alone,your call) - offer
Prices are for the parts alone, you are responsible for shipping costs.
pm or text me with any inquiries, I will respond to the best of my knowledge.
Jimmy by call or text: 262-664-3zero7zero
Plimptonjr
Pending Spyder and Intercooler pipes.
I also have the flexible disconnect lines that go from fuel pump to delivery hardlines but I have not taken a picture. In addition to that, i have delivery lines from bowl to heads, and pump housing bracket. Basically only thing I DONT have is the bowl drain line simply because it pissed me off and is no longer salvagable. LOL.
I will also trade for parts like:
7.3 Heads or complete longblock that needs some work(USEABLE parts that may need cleanup)
External Wastegate(s)
performance 4r100 parts
pretty much anything I DONT have in sig, If someone is returning to stock and has something I would like to work with you.
PM me your thoughts
