EBP/MAP? ?
Jesse_01
Prince George, BC. Canada
I may of missed a post with this info. I checked my ebp and map while my key was off and truck cold. I thought i has read that they were suppose to be the same.
EBP 0psi
MAP 13psi
forcefed6.4ford
Medicine Hat... Again
Sounds like you EBP sensor is about to sh!t the bed.
The other one is an injector control on start up DTC. Your batteries may be weak, or check your fuel filters. If those are ok you might have a bad harness for you HPFP.
BFT
southern cali
where do you live? seems like the guys in the colder areas or the northern states seem to have these same problems.
Jesse_01
Northern BC, canada.
Yeah for the most part it runs good. My fuel mileage has gone to **** about 90 days ago.
P2263 Turbo/Super Charger Boost System Performance --- reason I checked my EBP/MAP
P2291 Injector Control Pressure Too Low – Engine Cranking --- not sure want to check
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P1744 Torque Converter Clutch System Stuck in Off Position
I think those 2 are because my torque is cracked and filling the bell housing full of oil and is leaking like a mofo.
Shootingstar
NE OK
If your torque converter is damaged and not locking up that will not allow the truck to boost up like normal. It won't lug as much. So that maybe setting the turbo codes as a result of that problem. Fix your converter and go from there.
White_monster
The great white north
P2291 came up on mine when I had a leak before the hpfp, turned out to be one of the copper crush seals at the hpfp for the fuel supply. Changed it out and good to go. This can be done with the turbos in the truck and obviously cab on
