EBP max psi?
MeTo
What is the max psi an OBS EBP sensor will read? I plan on trying a .84 housing and want to monitor the boost/ EBP ratio using the EBP sensor. Might need to go mechanical? Hopefully, I will be able to accomplish this without playing musical housings? Is a gate in my future?
MeTo
Yes Torque Pro, I'm trying to find out what the max psi is that an EBP sensor will register?
Parker, TX
Bottom Line: I think it is 60 psi, but see the attached for more info. Hope this helps. Cheers!
  • EBP Into.pdf
