EGR Delete for 6.7
MorganM
SE Houston
Am I able to order the EGR delete plates, that are included in the EGR Cooler delete, seperately? They appear to be aluminum and/or SS, and likely more rust preventative than the H&S kit.
The H&S plates look to be mild steel- but I've only seen pictures and may be totally wrong.
Thanks
MorganM
SE Houston
I dont think I asked the right question- I'm looking for the 2 diamond shaped plates, where one is provisioned for a factory EGT sensor.
Bobby@MPD
Yes, we have those $99...just call the shop and place the order, or stand-by and ill put them on the site
MorganM
SE Houston
Order placed...I think it went through? Missed the field to enter the PSA member discount though.
Thanks Bobby!
TRUBBS
Balls Deep
i need to order a set, out h&s ones are already rusted to $h!t.
do you guys have the coolant "condom" caps also? i had to hose/bolt plug ours cuz it started pissing coolant out the other day.
Bobby@MPD
for which engine?
Pizza pig
MD
Yes just shoot me a pm ill get you taken care of bud
Hellen Keller sent this?
MorganM
SE Houston
Pizza pig
MD
That's the full delete, right?
I'm referring to these instructions wherein it appears I need two plates- one for the sensor, and one as a block off.
http://www.hs-motorsports.com/instructions/fordegt.pdf
I expected that you were sending me the sensor plate and block off plate- I only received one piece(for EGT). I still need the block off, correct?
I got you covered. Shoot me a PM sir.
