Fordtrucks
- Joined
- Mar 9, 2013
- Messages
- 503
- Reaction score
- 0
Can anyone give a break down of the wires going in to my fan? There's a plug at the top of the radiator. I'm installing an electric fan kit with a controller. The controller wires directly to the battery but has several probes on it to turn the fans on several different ways. My stock fan is set to kick on at 212° so if I can use that as one probe that would be cool, then a switched 12v from the AC to kick the fans on for that and ide be set. I'll also wire in one of my upfitters so I can manually fire them up if need be.
Is there a couple wires within that factory plug that will provide my 12v signal that I can use? Thanks guys!
