Engine oil usage??
bdm1981
Salem, Missouri
I just did my normal maintenance draining the water separator and went to check the engine oil and it was almost a quart low. Was showing oil up to the bottom of the hatch marks on the oil dipstick. I have drove the truck off and on during the day so I know that its not quiet accurate since I should check it when its cold. Truck has 9200 miles on it and I change the oil every 5000 miles. Truck is just a daily driver so I haven't really towed anything with it and I don't run the crap out of it. I also run Mobil 1 5w40 synthetic oil in it. Just want some input from some of you guys to see if its normal. Thanks!
