Excurson rear Sway Bar bushings
dzldoctor
Anyone have a line on rear sway bar bushings for factory sway bar for an 04 excursion? They are discontinued from ford and have no luck finding at part stores. Or just opt for a hellwig bar?
Jeremy
Utah/Montana
You could always change out to the 30mm one that was used in the trucks. Its an upgrade for the excursions, and the bushings are still available for it. All you change is the sway bar its self and the bushings, it bolts right in.
dzldoctor
OK Good Idea. Thanks I'll see if I can find one. Are the mounting brackets the same?
Jeremy
Utah/Montana
Yes. You'll have to get one from the junk yard, 99-04 trucks is what you're after. If you did the B mod to your rear springs get the drop links too. You dont need them, the excursion ones work fine, but if you raised the rear the truck links work better.
Most ex owners change out to the bigger 30mm truck one, they handle better with it.
