Exhaust manifold
SDS97_7.3
Finksburg, Maryland
Ok the problem I'm having is on the passenger side where the manifold and up pipe meet, is where my first leak started (other is driver side donut). The leak has burned a whole between the 2. I wanted to know if the manifold could be brazed or welded when I pull it off, or if I will need to just replace the manifold? Thanks, Steve
Tom S
I would put on a new manifold. You can get most of the bolts with the wheel off with the impact.
