FRP sensor install link please
sweetdreamz
north port, FL
Threw a code for low rail pressure when i lay into the throttle, no change in trucks driveability or performance so i believe its just a bad sensor. Pretty sure this topic has been brought up before but I cannot find any install posts or links, please help, not sure what to remove or easy way to access this sensor.
Quick edit .... 2012 f250 6.7
DEEZUZ
NO PUKESTERS
NWI
Super rare.... I'd pull the regulator out of the pump first and check for metal debris. Hours/miles on engine?
DEEZUZ
NO PUKESTERS
NWI
Yup. I wouldnt put a dime into it unless you verified fuel pump isn't coming apart. Remove upper/lower intake, T25 and remove the metering/vcv/fp regulator atop the pump. Check the screens for metal. If so, it's game over....
I have NEVER ever just replaced a FRP sensor. If I was a religious man I'd be praying for you
