FS: 2008-2010 F350 suspension parts
Stroked777
Glenrock, Wyoming
Just put a lift on my truck and have no need for any of the following stuff
-f350 stock rear suspension blocks(2)
-f350 stock track bar bracket(1)
-f350 rear u bolts(4) w/nuts
I have no idea what the stuff is worth so make and offer, buy covers shipping. Everything is in good shape, no cracks just a little surface rust. U bolt I'm not sure are reusable but if you are in a pinch they will work. Any questions call or text 518fivetwo7nine674. I can get pictures if you need
HeavyAssault
Middle, VA
I don't know for sure since in the past it has been said some are flat others have a taper. I guess it's for the drive line angles.
Stroked777
Glenrock, Wyoming
I'll take a look. I believe they are flat. The new blocks I put in from pro comp are tapered. Now my pinion faces upward towards the trans as a opposed to being level with the ground
Jayz
Stock blocks are all flat. Weather the 1 7/8" or 3 3/4" block.
