Fuel issues
1995f2507.3
Has happened a few times and with letting it sit has fixed it. Anyways everytime I start the truck I cycle the glow plugs 3-4 times just to be sure and usually starts right up well if I keep cranking for a few seconds and try to start it again I loose all my fuel, what could be the cause of this? It's all stock SAID the owner before me who put 160cc/30% injectors in it.
Bugman
Gypsum, Co
Your glow plugs will stay on for up to 2 minutes after you turn the key on the first time so there is no need to keep cycling them. That just puts wear on the glow plug relay.
How are you telling that you are loosing all of your fuel? Do you have a gauge on the FPR that is showing you the fuel pressure or are you just guessing?
It could be either the low or high pressure side of the fuel pump, or do you have a e-fuel set up?
1995f2507.3
I'm guessing I have no fuel, when the truck cranks it smokes and there's no smoke at all, I have mechanical fuel pump
