Glow plug removal
StrokiNDieseL
Geneva, Fl.
Doing the removal of the glow plugs and have a question on the ground that runs to mounting bracket from firewall. I’m Installing plugs from punch out so all glow plug related stuff will stay out of truck but what about the ground wire, can I just remove that also? Thanks
Roccafellas
Shouldn’t remove any grounds, I may be wrong but you’re passenger battery grounds your block and your block grounds your body so I wouldn’t but that’s just me.
StrokiNDieseL
Geneva, Fl.
I’ve alway heard trucks have problems if grounds are missed on these 6.4’s, good or good connection can be troubling.
