Grinding starter
Max_Mowry
Hi, not sure of this is the right place to post, but I'm having some problems with my starter and truck in general.
My problem occurred after I removed the engine and separated it and the transmission. I did a new seal on the input shaft of the transmission then put the tranny and engine back together and back into the truck.
I have everything back in and I tried starting the truck and it fired right up. The only problem is the god awful grinding noise. It was constant. When the truck started and ran.
I pulled the inspection cover off and the teeth look like they have ware, but nothing abnormal. I also put in a new starter today, batteries a week ago, and I connected the two pins on the relay and the relay is in working order.
I'm positive I pit everything back in properly, crank spacer, flexplate, torque converter etc.
Anything I should be looking for? I've tried just about everything I can think of to fix this and nothing has worked, anything would be appreciated.
Thanks
1997 7.3l PSD
FL
Did you put the fly wheel on the right direction? It has a offset.
I'm assuming it was starting fine before you pulled the motor?
How old is the starter?
