gt3582r
madman1234509
mayfield, ny
Going a different route and buying a gtx for my set up in the future. Bought this off of another member who decided not to use it as well. To my knowledge is has around 500 miles on it. This is a 61.5mm compressor, 68mm exhaust wheel. Ball bearing. No shaft play or issues. Only issue is I AM NOT selling it with an exhaust housing. Bright side is it allows the buyer to buy an exhaust housing that suites them.
$600 plus shipping
madman1234509
mayfield, ny
Yea, it would take a good bit of modification to fit in with the stock atmosphere. Probably more than its worth. Better off running it as a single kit with a bigger one in front of it. Like Randalls new set up, or a full custom build like mine. A few people have used this turbo or similar with great results.
RSK
Connecticut
Well my intentions were to use it with an rcd 75mm atmo but that's stock appearing so i guess its probably not a good idea.
madman1234509
mayfield, ny
Yea, without some custom fabrication it probably wouldn't work. Although it'd probably be a pretty cool set up. The guy that came to CT with me would be happy to make it work for ya ;-)
RSK
Connecticut
i have no doubts he could make it work for me, but i'm guessing he is extremely busy and probably doesn't want to waste time figuring out how much it would take for it to work with the rcd 75 i have. probably better off just buying a 59 from rcd like i planned on.
madman1234509
mayfield, ny
Does not come with the exhaust housing...
RSK
Connecticut
Screw it ask Rob if he has an idea of how much it would cost to make this work with a factory appearing low pressure turbo, obviously i know he would need my truck for a few days minimum to make whatever is neccessary for it work. Also what does an exhaust housing go for these days 3-600?
madman1234509
mayfield, ny
For the price of the turbine housing I'll throw that in as well for the ease of the buy. It is a cast housing from ATP. Divided T4 with a 1.06 AR. The housing is a little over 400 after all said and done, so 1050 plus shipping with the brand new exhaust housing. 600 plus shipping without.
This is a great little turbo for a moderately sized compound kit. Only reason for selling is I'm upgrading to the same size just a gtx.
