Headers I've been working on!
sonic_superduty
waynesfield,Ohio
Got the flanges in earlier this week, and this is what I have for the passenger side so far, still cutting and fitting the drivers side. Then I will fit the collector and a v-band!
sonic_superduty
waynesfield,Ohio
Thank you boys! They will be getting ceramic coated when done.. when I finish the drivers side I will have 3 bungs welded in 1 for pyro, 1 for drive pressure, 1 for back pressure sensor
sonic_superduty
waynesfield,Ohio
Tubing is 2 1/8 mild steel, I didn't want to use stainless due to too many heat cycles and possible cracking... thanks alot boys trying hard to make all of this come together
Powerstroked162
On Da Juice
Wa. State
That seems kinda big? I only ask because I would buy a set from you for my truck but I am worried about velocity with 2.125"
I want to also point out that it looks like you are making each runner the same length in tubing, I like it. Thats foreign to some people lol. Looking great though
Powerstroke Racer
Brenham TX
Nice job and hope they work for you but tubing is way too big, 1 3/4 is on the big side for the RPM band they will be used in.
Magnum PD
VA
Have a feeling 6.0 members will be sending you PM to make them a pair.
sonic_superduty
waynesfield,Ohio
Well they will be singing the high C note! Yeah there will be alot of tig work, but ill try to keep them within reason! Thanks for the feed back im back at it tomorrow with them
