headgasket?
Groomzybanshee
St Joe mo
have a truck in the shop that the coolant resiovor is empty but when you start the truck it fills up? and smokes a little white you think its got a blown head gasket or cracked head? or could the rad just be plugged up. truck also runs/smells hot.
Tom S
I would say head gasket as the more likely issue. Have you tried pressure testing the system. I think that is what I would try with the glowplugs out.
