Hello from Wisconsin!
BrewTown
Oak Creek, WI
I'm Jim from the Milwaukee area. I've been a member on a couple other forums through the years. Lurked here in the past and was referred here after asking about my '60 build. Look for it if interested. Will be a slow project to warn you though. Lots on my plate. You can ask, but I'll warn you, I might tell you then...
I've had my 01 7.3 hand shaker since 07, currently has a dead hole. Found part of an oil ring on the magnetic drain plug. Has some injectors and a KC.
Current is my 05 F350 auto. Studded, ******d, fuel system I built and a billet trans. Otherwise stock, for now... Needs injectors pretty bad, will go bigger.
