Help Diagnose ESOF
Zmann
the 90* bend on the pump should slip of the line and then u can slip the line into the tee
get a new line for the vac jumper and u should be able to reuse the fittings
Zmann
I bet you can find them
the air vac lines seem to have pretty standard assortment of sizes anymore
slee22
College Station, TX
Update: This weekend I replaced the lines to the hubs, rerouted the vacuum lines to/from the pump and repacked the hubs (just to make sure they operated smoothly). All is working!
I'm thinking the previous owner had leaks in the hub lines and didn't want to chase down the leaks so he went ahead and bypassed the ESOF system.
Thanks for your help Zmann!
