Help, oil pan bolt torque spec
Clean-15
Took my truck to the dealer and left it all day after a two week wait for an appointment. They called me at 3pm and said they couldn't do the oil pan reseal or a tire rotation. I told them put all the parts in the truck and I'll do it myself. Fricken crap since it's still under warranty. Anyhow, anyone know the torque specs for the lower oil pan? Thank you in advance!!
78f100
Bonifay FL
Should be 89 inch pounds. There is a sequence to follow also.for lower steel pan, apply a 0.133" diameter bead of sealant 0.039" outward of the chamfer on sealing face
below, tightening sequence of the 15 bolts
7 .. 5 .. 3 .. 2 .. 14 .. 12
9 .......................... 10
11 ......................... 8
13 ... 15 . 1 .. 4 ...... 6
I got this off line, but it sounds right. I can be certain tomorrow when I get to the shop.
