Help with Morimoto HIDs
jaynick1
Texas
I am installing some retrofitted head lights with morimoto d2s projectors and xb35 ballasts and relay.
When I plug everything up, the lights turn on and off perfectly for 3-5 min then both shut off and will not turn back on no matter how many times I cycle the switch. It doesnt matter if the truck is running or not. I can hear and feel the relay clicking on when I throw the switch but neither of them fire.
I have quadruple checked the grounds on both sides and all of the wiring leads for looseness. Nothing is hot or seems out of place. I am really at a loss here and any ideas would be appreciated. Thanks.
BIG JUICE
Valrico FLA
morimoto ballasts are known to either last forever or they are bad within mins or days of install. I would have said that was it but since I read your post to be both at same time I would guess the wiring relay is bad.
Are you using that h13 relay thing from retrofitsource? I have a used one I thought was bad and swapped out, but think its actually the projector shroud not working. didn't bother to check before I finished headlight retrofit. I will mail it to you just pm your info
jaynick1
Texas
Figured it out late last night. The 12v power wire to the relay had worked its way out of the plug. It was giving me fits because it wasn't loose enough to duplicate until I found it. I am never in a good mood when the multimeter comes out... But all is well thanks for the response.
powerlifter405
Butt Town
I had an ebay set do the same thing, plug a little loose. I took apart recrimped and viola'. I've ordered from several different vendors and the only vendor I had issues on water intrusion on the ballasts or failing bulbs was the retro vendor here.
I just did the TRS camry swap using their kit. It took some modding but it uses the MM H1 projectors. Decent beam but was looking for something w/ a broader smoother beam w/ a bit more distant.
Are you pleased w/ the D2S pattern? Light werkz dot com is a TRS and acme vendor and they had the acme versions of the MM D2S so I grabbed those on sale this week for the F350.
