Steve's red stroker
I was driving to work and the truck would buck occasionally on the highway, thought my cps was on its way out, pulled into the parking lot and it died there. I changed cps and still nothing, I then plugged in the scanner and only had 150 psi of high psi oil. So I grabbed my spare hpop, icp, and ipr. Came back the next day, and it started and ran for about 1 min, just enough to get it in the shop, I changed the ipr, it started right up and the ipr duty was @ 7% @ 1400psi at idle for about 30 seconds then dropped off and died about 30 sec later, I then changed the hpop and icp and can only get up to 150 psi after about 10 seconds of cranking and it won't go any higher. And the resivior is full. Now I'm lost any help would be great
