High output Alternator
06KingRanch
Austin, TX
What is a good High Output Alernator? My stock on is on its way out and looking for some feed back on what brand to go with.
Extended Power
I wanted a DC power unit, but ended up with a Mean Green 200 Amp.
Biggest concern I had was the clearance between the discharge piping, and the back of the alternator.
Here are some pix showing the size difference between the stock, and bigger MG case.
g2shuck
I have a large case high output mechman... hand built in the us for less than $200 shipped and 200 amp output... 120 amp at idle
chappy
Marshall Mi
I ended updoing a 140amp large 6g case alternator for a two alternator system combined with a smaller ovrdrive pulley. Works way better then my stock alternator. Tried 3 of them and no stocker could keep up. The one now is stock but 140 compared to 100 from the right on for my truck. Combinedwith the smaller pulley it charges nicely at idle even with verything on.
Snake
Flo Rida
Only problem with running a smaller pulley without having an alternator designed for the extra rpms is that it tends to shorten the life of the alternator.
Extended Power
Yup.
I ran one of Doug's smaller pulleys on my stock alternator...but at 41-4200 rpm...the alternator is spinning at over 12000 rpm.
It no rikey.
