High rail pressure help
Bryce_fow
So of corse I am out of town in the mountains I was coming to a redlight and the truck died started back up and now my rail pressure is staying high like 8.9 on my mini until I give it gas it dropped to 5.5 then goes back to 6.2 at the red light when I take off all is fine till I stop again then it dies no white smoke no running bad any help I am about to try retuning it
My09Ride
Central Pa.
Other will tell you this. Not enough info. Outside temps, what's been done to truck, and any codes?... In a mess we get in a hurry.. More info needed.. Lots of smart, and caring people here! ;)
Bryce_fow
It’s got
New block
New rods
New rcd fly cut delipped pistons and coated
bd manifolds
no limit uppipes
Bd turbos
No limit intake
Beach fuel bowl ******
Mishimoto intercooler
Mbrp cold side pipe
Diesel site boots
New hpfp
New fuel rails
New injectors
New water pump
New heads o ringed
New rcd stage 2 springs
New rcd Molly push rods
Fass 150
Bdp sump
ARP studs
New oil cooler
New hd lifters
New rocker arm
H&s mini maxx with byall tunes
5in flo pro
Egr relocation to the floor
Snow performance water injection
No codes
And it’s about 57 outside
DEEZUZ
NO PUKESTERS
NWI
Frp sensor?
I usually don't do anything until I change that first
Bryce_fow
This might sound stupid but I think it might have been a frequency of some sort because it did it again in the exact same spot but only in that spot drove 5 hours today never did it again
