Higher oil temps
Poglife
Georgia
Anyone have any ideas as to why my truck would run warmer than it should 04 6.0. Running 70-75 itll run 200 ect and 208 eot. If I get on it at all it gores up to 215-217 eot. This was 82-85 degrees outside does the same when its cooler out. I'm running delo 400 le 5-40 also was the same temps with motocraft 15-40. Put in a new oil cooler Hoping it would change no luck. Also if I hook my camper up to it after 20-30 min of driving it's 215-230 then I pull over let it cool off. Any help would be awesome
03_PSD
Salado, TX
Could be your fan, some switch to the snow plow set up and have great success.
Snow plow fan clutch 4C3Z-8A616-SA.
Zmann
oh good
some companies are sneaky and make it look like they are selling OEM and sneak in a Dorman or worse
Poglife
Georgia
Got a fan clutch from junkyard today and went for a drive with the 5er everything seemed better it was Lil cooler today 65. But noticed my tranny is starting to take a dump waheww
