Hot wire in the rear end. 06 F250
stephen66
I want to wire my backup camera and need to locate a wire which is hit when the switch is on. Help appreciated.
Zmann
look in the trailer 7 pin harness
the 7 pin cover identifies the wire
or like most folks do use the reverse bulb + unless you want the camera to be on and available all the time while the key is on
stephen66
Thanks. I had it on the reverse but tapped into the +\- on the trailer wiring to make it hot in demand.
