greenthunder7.3
i have a 96 7.3 with high miles as a work truck and it won't start unless you give it a little spray ( yea yea i unhooked the glow plugs) i have been reading up and trying diff things. it passes click test and they all sound good. passes cylinder contribution test. glow plugs all work but one and its hotter then hell so it shouldn't even need them. i pulled the injectors and resealed them. watched on my ae while cranking and it starts building icp right away and will go up to about 3000psi and 45 percent duty cycle. 45 psi fuel pressure once it starts. every once in awhile if you have been driving it for a couple days it will start on its on. it smoke white like crazy while cranking and for about the first coouple minutes of running. i don't have a compression tester but i did a differential pressure test on the cylinders and all seemed good. one was a little less then the others. the level in the resivor in the moring is probly between 1/4 and 1/2 inch from the bottom of the plug. with it building such good icp pressure i would'nt think that would be the problem or the injectors poppets rushing oil out. is something messed up with the fuel side of my injectors or am i missing something. it has been doing this for sometime but i don't drive it very often but i'm wanting to get this figured out. any ideas would be appreciated.
