Buffalo444
How much can one of these handle power wise? I'm debating on putting it in my current truck (rusty pos OBS) or waiting until I get another super duty. I'm wondering how the 4.14 first gear will fair towing with 4.10s too...
Hey Charles,
Any pix or write up on how you did your cooler install? What did you use for a pump and suggested gallons per hour? What would be a normal op temp for the ZF? Reason I ask is I swapped out my E4OD and left the v10 cooler in the front bumper and the tranny temp gauge in the pod to, so just looking for ideas as it's on the list of too does.
Thanks
Jrc
You can put an external pump on the ZF-5, but it won't be a cheap endevour! I thought about it on my 94. You will need to modify the PTO covers for inlet/outlet ports (or find a couple of Fabcraft Metalworks billet covers that have the ports), get a pump (Weldon 9200-A, Tilton 40-525, or Mocal 17-522HT ... $200-$400, get one with Viton seals), Temperature Switch (don't want to pump when its below temp), Cooler, and of course all the fittings and lines. The pumps are usually around 0.5-2.0 GPM. Cheers!
