How much paint ?
Smokin 6.0
Indiana
I will be painting my 2002 extended cab short bed F-250 in the spring and am not sure how much paint/primer/harder/reducer to get .I plan on taking all the doors, fenders, hood and bed off to do this. Painting all pieces separate from the cab so i can get the whole truck covered. Any help is appreciated !
Craigsville VA
Which ever shop you get your paint from can figure that up for you. When I painted my reg cab I told the paint store what I was painting and they figured it up for me. It came out pretty close to perfect. I only had a little of each color left over. What brand paint are you using? I used ppg omni plus. It's not top of the line show car paint but not bottom of the line either. Mine turned out really good. Hope yours does too! Good luck!
Wojo
Gallon of base, gallon of reducer, two gallons of clear. Don't go out cheap either. Plan on spending at least 1000$ on paint supplies.
