How to make 7.3 exhaust loud as possible
cabloom7.3
I only i a 3.5 inch straight pipe on now but im going to get to a 5 inch. Is there anything else you can do to get the exhaust louder? I also have an aftermarket filter which probably helps with the whistle. Also is there anyway to calm the engine noise down? I think i have some leaky up pipes that dont help but any other tricks? Thanks
BigRed97
Saugus MA
I only i a 3.5 inch straight pipe on now but im going to get to a 5 inch. Is there anything else you can do to get the exhaust louder? Aside from more air and fuel, no.
I also have an aftermarket filter which probably helps with the whistle. Also is there anyway to calm the engine noise down? some tunes are louder than others, depends on the tuners style. Also you can try coating the VCs with LineX or similar(others have reported a slight improvement) I think i have some leaky up pipes that dont help but any other tricks? Thanks
:toast:
cabloom7.3
Also is it worth the money for Riff Raffs FRx system? Will this help with the noise.
And i think the hutch mod is on my list as well
I was going to say stick your ear in the pipe.!
Put a.stack on it. Those are loud.
Bobby@cp
Or you could do this.....
It was loud.
Lamont_24
Edwardsburg, MI
X3 on taking the turbo off. Or you can put a muffler on it. The back pressure from the muffler helps exceed back pressure which in turn makes the truck louder
dmd
Denton, TX
A weak IDM makes the engine more noisy. The swamps IDM made
mine even more quiet.
Hi flow turbine outlet made my exhaust louder, 38r probably helped too.
02BigD
Coastal NC
There is absolutely no need for exhaust manifolds...other than the silly EPA. Get rid of them biches, and sound like no other.
