Hpfp o ring leaking oil
F150orelse
Has anyone had this problem with the Hpfp o ring leaking oil into the galley? It's not a constant run or puddle of oil yet. The pump has never been touch, I guess it would be an excuse to upgrade to the 2015 pump.
Mesa, AZ
If its an 11-14 it is probably the fittings for the oil line on the turbo. I would replace both and the tube at the same time. And while you are under there, tue coolant line and fitting are known to leak quite frequently as well, id probably replace it too.
